We've just completed the next development step on our journey to create a mobile app with the full functionality you know from the desktop! So we'd like to share the beta version where we’re introducing calendar, contacts, notes, and tasks support.
Our goal is to complete the feature set while making the app as powerful and seamless as possible on all devices, and we can't do that without your feedback. That's also why, based on your suggestions, we've made it possible to adjust the font size across the app and we've tried to improve the user interface to make it more intuitive and user-friendly (especially on tablets). We'd love for you to try out the beta and share your feedback!
What’s new?
Calendar
Functionality for both local and synchronized Calendar is now available in the mobile
app.
Have all your events and schedules at your fingertips everywhere you go! Accept invites
directly from
your messages, create new meetings, view your events in a number of views (week,
month, agenda views you know
from the desktop app and even a special Three days view for the upcoming 3 days) and
more!
1 / 3
iOS - Month view
2 / 3
Android - Week view
3 / 3
iOS - View selector
Contacts
Instead of using just your mobile device contacts, eM Client has a full Contacts
management features to
synchronize and edit your contacts and initiate new messages, calls and more.
You
can also view Communication
and Attachments history.
1 / 2
Android - Contacts list
2 / 2
iOS - Contact details
Tasks
Planning and organization is easier than ever, wherever you are. Create and organize your
tasks and sync
them to
your devices with supported accounts.
1 / 2
iOS Tasks
2 / 2
Android Task Detail
Notes
Create notes directly in the mobile app the same way you can in desktop,
Exchange and IceWarp accounts
can also
synchronize them across devices.
2 / 2
Android Notes
1 / 2
iOS Notes Detail
Customizable font size
One of the most requested change is here - you can now make the font inside the app the size you
need to
read
comfortably, instead of the size being taken only from your system setting.
Custom sort for all lists
The sorting functionality was added under the filter icon, the same way it is in the
desktop version,
for all
lists.
Tablet UI improvements
We have improved the interface and layout for android tablets and iPads to more closely follow the
desktop
version, making the app more convenient to use on a bigger screen than your phone.
You can now pin or unpin the folder list on the left or collapse the message
list if you need more space
to read
your messages comfortably.
1 / 8
iPad
2 / 8
iPad
3 / 8
iPad
4 / 8
iPad
5 / 8
Android Tablet
6 / 8
Android Tablet
7 / 8
Android Tablet
8 / 8
Android Tablet
Performance improvements for iOS
Using your feedback, we were able to find the places to tweak to improve speed of the app on apple
devices.
And more fixes
How to install the new BETA update?
iOS
To join testing of the iOS app make sure to install Test Flight on your device.
Then use the link below to install the new version:
Android
To join testing on Android go to the eM Client page on Google
Play store. Scroll down to the Join the beta
section and click Join.
Make sure to share your feedback at [email protected]!
